Fixed.
Old Mar 10, 2014 | 04:13 PM
mirabileboy's Avatar
Default Fixed.
Old Mar 10, 2014 | 05:31 PM
d-bo's Avatar
they will be fine as long as it is tight
Old Mar 11, 2014 | 05:27 AM
Hershey's Avatar
Where did you get the oil drain adaptor?
Old Mar 11, 2014 | 05:44 AM
RAIN H8R's Avatar
Use thread tape and the typical practice for it and youll be fine
Sent from my Samsung Galaxy S4
Old Mar 11, 2014 | 07:12 AM
RAIN H8R's Avatar
You have the correct parts. Just use teflon thread tape...correctly...and you will be fine!
Old Mar 11, 2014 | 11:32 AM
Hershey's Avatar
Originally Posted by mirabileboy
Here's the oil drain plug adaptor I bought, let me know if you guys see anything wrong with the size,ect:
http://store.42draftdesigns.com/Univ...Plug_p_58.html
Thank you.
Old Mar 11, 2014 | 03:05 PM
turbo8765's Avatar
I have the exact same setup. No leaks even without teflon tape.
Old Mar 11, 2014 | 03:42 PM
Alloy Craft's Avatar
Former Sponsor
Yeah it's as tight as I could get it. Thanks d-bo
Use a torque wrench. Too tight can strip the threads.
Old Mar 11, 2014 | 05:59 PM
99SH's Avatar
I had a similar setup and glad I got rid of it. Draining the oil and having to remove the wiring harness from the sensor was tedious. I could see the harness clip eventually breaking off in the long run due to fatigue.
Old Mar 13, 2014 | 07:54 AM
99SH's Avatar
So I tested the force it would take to unclip the sensor. PITA. Took a good 10 min to get it unclipped. It might be easier once the clip is stationary by being bolted to the oil pan. 99SH, you were so right. This is just a temporary set up until I get an oil cooler later on (if needed).
I ended using a sharp pick to lift the clip and pull it out. The harness is built pretty well and wasn't intended to unclip/reclip.
One way to get around this is to use those quick drain valves; therefore you can leave the sensor in place while draining. Just an idea...
