flex fuel sensor fittings
Old 04-29-2015, 05:34 AM
liquidgsr's Avatar
Default flex fuel sensor fittings
Anyone know where to get the flex fuel fittings like the ones supplied by SOS. I wanted to get the clips that attach to the ends and the AN fittings for it. I have to see if I can get my Digital logic to read the out from AEM for it or if I will need the zentronix gauge to read the content for E85.
Old 04-29-2015, 05:46 AM
staylor725's Avatar
i used russell fittings.
http://www.russellperformance.com/mc...injected.shtml
Old 04-29-2015, 06:59 AM
CoolGuy094's Avatar
The best option would be the Russell fittings; you can find them on Summit Racing.
Old 04-29-2015, 07:00 AM
liquidgsr's Avatar
perfect. Thank you.
Old 04-29-2015, 07:06 AM
liquidgsr's Avatar
anyone know what size the continental flex sensor is? My return line is a -8.
Old 04-29-2015, 07:11 AM
CoolGuy094's Avatar
3/8"
So you need a 3/8" SAE female to -8 AN male.
Old 04-29-2015, 07:12 AM
CoolGuy094's Avatar
I probably have part numbers if you give me a bit.
Old 04-29-2015, 07:23 AM
liquidgsr's Avatar
sounds good I am not in a rush since the car isn't going to be running for a while. I am just starting to source things since the weather is getting better and I can slowly work on buttoning things up before I get the car running again. I will need to get the -8 fittings for the return line as well to tap into it. Thanks for the help.
CoolGuy094's Avatar
They only sell -8 in the threaded cap style, no quick disconnect style.
Blue: 644130
Black: 644133
Old 04-29-2015, 07:30 AM
liquidgsr's Avatar
How does the threaded cap work? Would you have to get the ends threaded then screw that on? I could always do the -6 to -8 adapter I guess.
Quick Reply: flex fuel sensor fittings
