Flywheeel for FI
Old Jun 22, 2007 | 07:19 PM
Venomous S's Avatar
Default Flywheeel for FI
I been running a TODA and here are some specs on others:
a)Toda = 9lb
b) AP1 = 15lb or so
c) AP2 = 20lb or so
what would you use?
light = quicker turbo spool up
heavier = torque down low
Old Jun 22, 2007 | 08:46 PM
TheCarGuy2021's Avatar
I didn't weigh my Exedy before I put it in, but it sure was lighter than OEM.
Not as light as the Toda though.
Old Jun 22, 2007 | 09:06 PM
2QYK4U's Avatar
Comptech lightened flywheel FTMFW!
Old Jun 23, 2007 | 09:19 AM
tbtak's Avatar
Thats what I'm using........with a ACT clutch pkg.
Old Jun 23, 2007 | 10:53 AM
blues2k3's Avatar
as I have indicated previously, the setup I gave you utilizes a high clamping load. Although Hondas are not prone to crank walk due to the thrush bearing, I have personally damaged two engines attributed to the extreme load. The lightwieght flywheel mated to that custom clutch will eventually cause harm to the motor. That is why I migrated to the 04 flywheel and resurfaced it a bit. Also keep in mind most lightweight flywheel does not go hand in hand with longevity.
Old Jun 23, 2007 | 11:42 AM
batikan's Avatar
i have Toda Flywheel but I don't like it. Too light and too much rattle on 1st. The best I've seen is the Competition 11lbs flywheel. No rattle, no noise at all. Besides, 2lbs heavier wouldn't make much difference.
Old Jun 23, 2007 | 11:55 AM
AirborneS2K's Avatar
AP2 20 lbs flywheel FTW....bitches.
Old Jun 23, 2007 | 12:18 PM
OGPackin's Avatar
Im running a Spec flywheel
Old Jun 23, 2007 | 08:08 PM
Tyraid2K's Avatar
I can promise you that you don't want the toda unit, I'm having trouble getting used to the 12lb competition fly, I also have their stage 4 cltuch
Old Jun 23, 2007 | 08:48 PM
batikan's Avatar
isn't the competition 11lbs?
