Ford 8.8 rear end question
Old Jan 16, 2014 | 04:42 PM
biohazarde's Avatar
Default Ford 8.8 rear end question
I'm in the process of getting the rear end so I can buy the full blown kit. My question is on full blowns website it says super coupe only. What's the difference between the super coupe tbird differential And the non super coupe rear ends, that makes the kit only "work" with the one? I have no clue about thunderbirds. And for all I know the non super coupe are solid axle or something. But figure is ask before I buy a rear end! Thanks!
Old Jan 16, 2014 | 05:44 PM
KaNgArOo's Avatar
I would like to know as well.
Old Jan 16, 2014 | 06:01 PM
herecomesboost's Avatar
Pretty sure the non-supercoupe Tbird diffs are not 8.8's (I believe they're 7.5's?)
Old Jan 17, 2014 | 05:11 AM
Phill24's Avatar
Correct
Old Jan 17, 2014 | 08:30 AM
biohazarde's Avatar
Well. Simple enough! Thank you.
Old Jan 17, 2014 | 09:12 AM
np *Tyler*
Old Jan 17, 2014 | 01:21 PM
sohc_mshue's Avatar
You can use a cobra 8.8, but it will not mount exactly perfect.
Old Jan 17, 2014 | 02:08 PM
WootRWD's Avatar
What year cobra?
I thought the 03 up had the 9inch
Old Jan 17, 2014 | 02:36 PM
clevelandmatt's Avatar
Not correct. 01-04 cobra's had 8.8 irs. You could also get one from an explorer which also had the 8.8 and are usually much cheaper to find. You'll need to change the diff cover though.
Old Jan 17, 2014 | 02:38 PM
Originally Posted by WootRWD
What year cobra?
Allen, the late 90s/early 00s were live axle and used an 8.8, I believe.
