Fpr
Old May 30, 2012 | 04:42 AM
jpetch05's Avatar
Default Fpr
With a walbro 400 and ID 2000 will I need a fpr to make 600 on e85
Old May 30, 2012 | 04:53 AM
Rollinx25's Avatar
You still need the fuel pressure regulator to help control the amount of fuel your going to use.
Old May 30, 2012 | 06:39 AM
vduber's Avatar
I think he meant stock vs an adjustable aftermarket one
Old May 30, 2012 | 06:43 AM
sohc_mshue's Avatar
With the stock regulator your base pressure will likely be higher than you want. The regulator will become a restriction due to the amount of fuel your pump flows. Your pressure will likely not be able to go lower than 55psi or so.
Xherrox
Mar 25, 2009 08:45 AM
chopper-world
Apr 23, 2008 03:02 AM
mrfast32
Apr 3, 2008 04:49 PM
adam_gipson
Aug 19, 2005 12:00 PM
CRX 18
Feb 8, 2004 02:37 PM
