Comp twin disc
Old May 7, 2012 | 03:49 PM
J-GO's Avatar
Default Comp twin disc
When the car is not running the pedal feel's perfectly normal and smooth. With the car running the pedal seems have a sticky (or notchy) feel to it, not smooth at all. The problem just started today, the clutch as 500 miles on it. Any one experience a problem like this? Is it release bearing related?
Old May 8, 2012 | 09:12 AM
neeman77's Avatar
bump I am having this problem as well with a different bearing setup. I think it is the master cylinder, I will let you know what happens after I change it this week. Anyone else have input?
Old May 8, 2012 | 11:42 AM
illestrolla's Avatar
My Pedal has a bit more "feel or feedback" while the car is running, but nothing notchy/sticky about it.
engaging/disengaging or both?
Old May 8, 2012 | 11:53 AM
neeman77's Avatar
http://www.youtube.com/watch?v=-a4VsYG0xeM
like this for me; squeeking and sticking
Old May 8, 2012 | 02:18 PM
passmans2kny's Avatar
your car looks dirty down there, i never had this happen with my twin, that sounds like some kind of spring noise
Old May 8, 2012 | 02:43 PM
neeman77's Avatar
lol thats not my car that is just a video I found on youtube. Hence A5 clutch sticking and squeeking.
Old May 8, 2012 | 03:09 PM
Uncoolron's Avatar
I thought you meant A5 sauce.
Old May 8, 2012 | 06:01 PM
J-GO's Avatar
Please let me know if the master cylinder fixes it. Mine squeaks too. It always had more feedback when running but nothing like this
Old May 8, 2012 | 06:40 PM
Did they start @ the same time??
The squeaking sounds pedal related, and wouldn't be the first Honda to do it. Kinda tricky to grease, but any work under there is a bitch.
The sticking however is interesting, is yours smooth on the way down and only sticks on the way up?
Old May 8, 2012 | 06:51 PM
neeman77's Avatar
Ive greased everything under the dash in the pedal assembly to no avail. If you really listen you can almost localize it to the engine bay, so I think the master cylinder should fix it. I already ordered it just waiting for it to arrive to put it in.
