FPR question
Old Sep 15, 2009 | 05:25 PM
myflys2k's Avatar
Default FPR question
I have recently installed a CTSC and have decided to go the route of bigger injectors instead of using the FMU. I have an emanage blue and just purchased RC550cc injectors. Im running 7psi and the walbro 255 lph fuel pump.
Do i need an adjustable FPR since i want to run stock fuel pressure.
Will i have any issue with the stock fuel pressure regulator running the walbro pump?
Old Sep 15, 2009 | 05:33 PM
TRBOKEV's Avatar
No bro you should be percectly fine with your setup. Good luck!
Old Sep 15, 2009 | 06:14 PM
smokeybear001's Avatar
I agree with TRBOKEV, all is well w/ the stock FPR
Old Sep 15, 2009 | 06:25 PM
myflys2k's Avatar
Cool thanks guys. Saves me a bit... put that towards some useful gauges.
Old Sep 15, 2009 | 06:26 PM
myflys2k's Avatar
Is the stock fpr 1:1? if i hit it with boost will it rise 7psi at wot?
Old Sep 16, 2009 | 04:50 AM
kawi10r998cc's Avatar
Yes stock FPR is 1:1. Yes if you hit boost fuel pressure will rise in conjunction with your boost. I run 14psi on stock FPR just fine.
Old Sep 16, 2009 | 06:28 AM
myflys2k's Avatar
Perfect. Thanks everyone.
CoolGuy094
Jan 26, 2014 03:54 PM
rikhemi
Dec 23, 2011 11:55 AM
JustinC
May 1, 2009 05:43 PM
mattf87
Jul 24, 2007 04:47 PM
02spas2k
Apr 1, 2004 05:04 AM
