Fuel System Setup with SC
Old Jul 20, 2007 | 09:46 PM
mattf87's Avatar
Default Fuel System Setup with SC
Hi all,
My current setup is an aftercooled comptech SC at the stock boost level. I've recently acquired a 7lbs pulley and an Emanage Blue with all the necessary harnesses and i'm planning on installing those soon. Though I understand that the typical route taken by other members when increasing the boost level involves removing the Comptech Rising Rate Fuel Pressure Regulator, and replacing it with either an adjustable FPR or the stock FPR, aswell as replacing the stock fuel injectors in favor of higher flowing units. Since i'm only going to be running 7 psi (where the stock injectors are still sufficient), couldn't I just keep the Rising Rate FPR in place and use the emanage to trim my fuel curve once i've set the fuel pressure to the right level? Let me know if my thinking is flawed.
Thanks for the help,
Matt.
Old Jul 20, 2007 | 11:14 PM
revhi's Avatar
Yes, thats what Im running. Just use the inj map to add fuel where needed.
Old Jul 21, 2007 | 03:39 AM
s0rted's Avatar
My friend was running that setup for a while - he found that it was a bit of a PITA to tune well though, and eventually went for a set of 550cc's.
Old Jul 21, 2007 | 05:28 AM
nightcrawler7188's Avatar
question: once you get it tuned, do you have to keep checking up on it or does it always stay the way you tuned it? and wouldn't you HAVE to get bigger injectors in order for the eManage to be able to get you to run more rich?
Old Jul 21, 2007 | 11:37 AM
mattf87's Avatar
revhi - does this mean that you didn't raise the fuel pressure and instead added more fuel using only emanage? Also you are 7 psi too, how close are you to max duty cycle?
Thanks for the responces
Old Jul 21, 2007 | 11:56 AM
Slows2k's Avatar
I ran a AEM 1:1 FPR and RC 440's with a e-manage blue without an issue. The biggest reason to switch to larger injectors with the e-manage is being able to ditch the rising rate FPR.
Old Jul 21, 2007 | 09:30 PM
revhi's Avatar
Duty cycle is at about 90% at full boost, no I did not adjust the FPR.
Old Jul 22, 2007 | 08:46 AM
mattf87's Avatar
--Thanks revhi.
--Slows2k, Why is an advantage to ditch the rising rate FPR?
Old Jul 24, 2007 | 01:47 PM
mattf87's Avatar
bump...anyone?
Old Jul 24, 2007 | 04:47 PM
Slows2k's Avatar
Better control over fueling than just increasing the fuel pressure.
The stock fuel injectors were not designed to work at 125psi as well.
lvd1102
Oct 22, 2009 01:20 PM
myflys2k
Sep 16, 2009 06:28 AM
demonderrick
Aug 20, 2005 07:45 AM
Salaska
Dec 27, 2004 10:15 AM
02spas2k
Apr 1, 2004 05:04 AM
