FRM compliant low compression pistons
Old Jun 3, 2008 | 10:10 AM
Soul Coughing's Avatar
Default FRM compliant low compression pistons
Hey Guys,
I'm looking to rebuild a block (my first engine build), and was researching into getting some low compression pistons instead of using a 3mm headgasket! I know that there are very limited access to FRM compliant pistons. Someone said Mahle made some, but i could be mistaken. Any info would be appreciated!
Old Jun 3, 2008 | 06:46 PM
CarbonYellowJ's's Avatar
Yeah Mahle gold pistons. I would contact them about a set. It might have to be custom. Dont know for sure.
Old Jun 3, 2008 | 08:39 PM
AusS2000's Avatar
I still don't know what makes pistons FRM compatible.
Old Jun 4, 2008 | 06:25 AM
2big4aS2000's Avatar
yes there is a solution out there - but if your not a sponsor you can not give out constructive comments without torment.
Old Jun 4, 2008 | 08:09 AM
Habitforming's Avatar
From what I recall reading (it's been quite a while, take your grains of salt with this info), it's a coating on the skirt (or maybe all the way around the crown?). If you look at the side of the pison perpendicular to the pin hole, there will be a large black area. Some other OEM's are adding it as a way to reduce internal friction on conventional sleeves, and thus improve fuel efficiency.
Prokaw875
Jan 28, 2015 12:23 PM
Bliss
Sep 18, 2013 07:46 AM
Dienekes
Oct 16, 2009 10:10 PM
synapse
Jan 5, 2007 11:06 PM
Team Hybrid
Nov 4, 2002 02:15 AM
