Fuel Issue
Old May 20, 2024 | 03:25 PM
SgtDuracell's Avatar
I already have upgraded wires and they seem fine.. i pulled my fuel pump and checked everything as well at the beginning of last season because my fuel pump relay went bad (thought it was the pump itself). Replaced that and it ran fine for a while up until this issue.
I just changed my wideband sensor and ended up changing the harness as well as i saw the connector was melted.
Still having the same issue unfortunately.
Hoping for any other ideas
Old May 30, 2024 | 04:50 PM
mys2k3's Avatar
Did you refuel the car just before these problems started? I’m wondering if it’s bad fuel.
Old Jun 6, 2024 | 11:35 PM
RolanTHUNDER's Avatar
Are you using the stock FPR or aftermarket (AEM, Radium, etc)?
Old Jun 6, 2024 | 11:37 PM
Originally Posted by SgtDuracell
if the wideband shows its rich wouldn't the ECU compensate? based on the readings it shows its really rich
That depends on the tune. If Series 2 then O2 feedback needs to be turned on with realistic AFR values to either enrich or lean out the AFR on the fly based on RPM and/or load.
Old Jun 9, 2024 | 09:43 AM
EOE's Avatar
EOE
What's your idle AFR?
amdaman
Jun 6, 2016 04:35 PM
liquid_helix136
Feb 27, 2016 11:08 PM
Irishflame27
Dec 13, 2010 05:28 AM
twohoos
Sep 26, 2003 11:08 AM
