Fuel Pressure Change Under Boost
Old Sep 25, 2008 | 07:26 AM
dsddcd's Avatar
Default Fuel Pressure Change Under Boost
I have been working on my Theoretical fueling tables and I was wondering how the fuel pressure is affected under boost? In the ideal world, we would see it increase pound for pound. I believe that our cars run 55-60PSI at atmospheric pressure and I have no idea what happens under boost.
Old Sep 25, 2008 | 07:51 AM
snakeeater's Avatar
Depends on your fuel pressure regulator.
Old Sep 25, 2008 | 08:47 AM
dsddcd's Avatar
Sorry, I am using the Stock Regulator now.
Old Sep 25, 2008 | 11:41 AM
CD7SirAccord's Avatar
The stock regulator is a 1:1 regulator, which means there is 1 PSI increase in fuel pressure per 1 PSI of boost.
Rising rate regulators (FMU) vary, you can get different calibrations such as 6:1, 10:1 and 12:1. which for every 1 PSI of boost on a 12:1 rising rate regulator will net 12 PSI increase in fuel pressure.
So in a sense, the stock fuel pressure regulator is a rising rate regulator, just not as dramatic as an FMU, as it is only calibrated for 1:1.
Old Sep 25, 2008 | 01:27 PM
dsddcd's Avatar
Great, that is what I was assuming however, you know what they say about assumptions.
jdmz
Apr 25, 2019 07:09 AM
JRSCGSR
Nov 17, 2009 09:23 AM
RAIN H8R
Sep 28, 2008 03:47 PM
chls2k
Feb 15, 2008 12:04 PM
oneaudiopro
Feb 23, 2005 01:11 AM
