fuel pressure drop
Old Feb 14, 2008 | 06:41 PM
chls2k's Avatar
Default fuel pressure drop
need help!
my fuel pressure is at 70 psi during idle, and it drops to 65 when I am on the gas, even with 5 psi of boost, fuel pressure still drop to 65, I am running a brand new walbro 255 high pressure fuel pump and a bosch inline pump, this explain the higher fuel pressure, from my understanding, fuel pressure should increase the same psi as boost psi, I switch out my 1600cc injectors with 1000cc running on E85, now idle is a lot more smoother, but we are running out fuel around 7500 rpm, and I am getting a boost creep running on my 8lb waste gate spring. help!!
Old Feb 14, 2008 | 07:03 PM
Spec_Ops2087's Avatar
What kind of kit and what kind of fuel pressure regulator
Old Feb 14, 2008 | 07:27 PM
chls2k's Avatar
I am running LoveFab gt1 kit with gt35 turbo, I ran with AEM FRP now I switched back to the stock FRP.
Old Feb 14, 2008 | 07:59 PM
I'd put a boost gauge on the line that runs to the FPR because when it sees boost, it should up the fuel pressure. Either its not seeing boost or its not working.
Old Feb 15, 2008 | 05:03 AM
2big4aS2000's Avatar
how much voltage do you have at your pumps? upgrade the power wire and ground to the fuel pumps, use the existing power wire to trigger a relay!
Old Feb 15, 2008 | 06:14 AM
Sideways's Avatar
The Walbro pumps run out of umph at higher pressures. If you run the larger injectors at lower pressure you may improve the situation.
Many of us have had to change out the pumps for new ones because our original pumps go bad at high pressure/high demand. It is almost as if the mfgs supply Chinese generic copy pumps or something.
Old Feb 15, 2008 | 12:04 PM
chls2k's Avatar
the Walbro pump is running on factory wiring, the other bosch pump gets power directly from the battery into a relay that gets turn on from factory pump signal.
so far, I like how 1000cc are running very smooth, we just need few more psi of additional fuel pressure during boost.
JuicedS2K
Jul 16, 2010 01:15 PM
dsddcd
Sep 25, 2008 01:27 PM
evf2000
Jun 30, 2006 08:56 PM
synapse
Jun 4, 2005 01:48 PM
