Fuel pressure drops
Old Mar 8, 2011 | 01:14 PM
rsmatti's Avatar
Default Fuel pressure drops
Guys,
i just plugged in the ems and I removed the air pump for evap. I turned they key and noticed the gauge on my fuel rail rises because the fuel pump starts,when the fuel pump turns off pressure drops to 0 in like 6 seconds.
Checked the car for fuel leaks and nothing came up
any ideas?
Old Mar 9, 2011 | 09:13 PM
Shftat9k's Avatar
Mine does the same, I think it should be holding pressure though.
Old Mar 9, 2011 | 09:18 PM
Sideways's Avatar
It's leaking down, probably at the pump in the tank. Mine did that and it was a broken clamp on the piece of hose attached to the pump.
Old Mar 9, 2011 | 10:25 PM
Moddiction's Avatar
Former Sponsor
What's the fuel pressure once you start the car? or will it not start and that is the issue?
Old Mar 10, 2011 | 07:49 AM
rsmatti's Avatar
My pfab mani is out getting milled a couple mm. All I did was turn the key to ignition. fuel pressure rises, and when the pump turns off it fuels pressure drops back to 0 in about 5-6 seconds on my fuel rail gauge.
I posted because I dont want to start the car if this is an issue.
If fuel pressure drops that fast will I even have enough pressure to start the car?
Old Mar 10, 2011 | 08:36 AM
donaldmejr's Avatar
Fuel pressure should hold all the time. My crx gets driven maybe once a week and I always pop the hood to check things over and the fuel pressure is always around 35-40psi from the last time I ran the car.
Old Mar 10, 2011 | 09:19 AM
DBXFX's Avatar
^^ that makes sense because when removing the fuel rail, you need to first relieve the pressure. Therefore, even after a car sits for days it should still have pressure at the rail. If you dont have any leaks, then it would have to be leaking somewhere at the pump
Old Mar 10, 2011 | 10:00 AM
rsmatti's Avatar
I'm taking out the Walbro now too see whats up.
Old Mar 10, 2011 | 11:02 AM
s2k dre's Avatar
Yea im sure something is loose at the pump.
Old Mar 10, 2011 | 11:25 AM
rsmatti's Avatar
I took the pump out everything checked fine I even blew through into the pump no air went through.
When I hooked the pump up back into the assembly I even blew threw the white hose on top of the assembly no air went through...
Ideas?
