Fuel pressure help!
Old Sep 5, 2017 | 08:12 AM
FinestS2k's Avatar
Originally Posted by rmerchant3
I'm still leaning towards a FPR if you have gone over everything else. Mine would increase as well but under boost it would not hold and actually drop.
I'm going to try a different relay. The one that came in the SOS kit is super cheap and is falling apart already. I used a double barrel crimper and everything. (Used to wire airplanes) I'm just so confused, gonna see if that changes anything. If not I'll wait till Friday to put the fpr on
Old Sep 5, 2017 | 08:51 AM
FinestS2k's Avatar
my gauge is old I'm going to replace it to be sure it's correct. My fuel pressure gauge is reading 75-80psi at idle with and without the vacuum line connected with no change and I'll blip the throttle and it drops to 55 or so. I'm thinking the fpr is def the culprit in conjunction with those horrible Injectors. AFR when hot get close to 16.8-17.0 so I shut it down. Guess I'll have to wait till Friday to get the FPR in the mail.
jdmz
Apr 25, 2019 07:09 AM
jpetch05
May 30, 2012 06:43 AM
chopper-world
Apr 23, 2008 03:02 AM
oneaudiopro
Feb 23, 2005 01:11 AM
CRX 18
Feb 8, 2004 02:37 PM
