Fuel Pressure Regs & Gauges
Old Jun 5, 2011 | 08:33 AM
redboost10's Avatar
The aem fpr is a stock replacement that bolts in the stock location and is made to run the stock fuel lines. Don't think itsll work to drill/tap for the gauge on it.
Tap the rail.
Old Jun 5, 2011 | 10:06 AM
spectacle's Avatar
Surprised no one suggested this.
http://prosportgauges.com/amber-whit...ure-gauge.aspx
Electronic fuel pressure sender mounted to your AEM FPR 1/8 NPT port, and wire the rest up like you would any other gauge. Easiest way to go.
Old Jun 5, 2011 | 10:27 AM
redboost10's Avatar
i dont think the aem fpr has a 1/8 port on it. but he can tap the fuel rail is use that. just a more expensive way of doing an isolator kit
Old Jun 5, 2011 | 10:37 AM
spectacle's Avatar
In that case, yes you'll need to tap the rail. That's the route I would go.
Old Jun 5, 2011 | 10:41 AM
redboost10's Avatar
same here, thats how i am logging my fuel pressure with motec.
Old Jun 5, 2011 | 02:52 PM
Ap2spoonf20c's Avatar
I guess I'll go with a B&M gauge or something similar and tap the rail. So..just tap the top of the rail towards the front of the motor?...No specific location or any other small details I need to know about before I start drilling?
Old Jun 5, 2011 | 02:53 PM
Also, any other close up pictures would be greatly appreciated.
Thanks in advance! =D
Old Jun 6, 2011 | 11:15 AM
Bump
Old Jun 6, 2011 | 01:04 PM
redboost10's Avatar
Tap it wherever on the rail. It's best to use a mill if you have access to one but a drill press will work.
Old Jun 6, 2011 | 01:59 PM
japancrx90's Avatar
tapp mine with a hand drill, some loctite tread sealant no problem at all, just drill the right size
