Fuel pressure settings
Old Mar 18, 2010 | 03:21 PM
JDMallmotorAP1's Avatar
Default Fuel pressure settings
Im just getting an idea I was just wondering what Fuel pressure everyone one is set at?
I tried to search around to see a good bit on fuel pressure settings and not much came up.
also if you want you can throw in a lil more info if you like such as, injector size, fuel pump size, etc. and please make sure to say if you are turbocharged or supercharged.
thanks
I have my Fuel press. set at 40psi with 1000cc injectors and 255lph fuel pump
Old Mar 18, 2010 | 04:15 PM
Tech7427's Avatar
id leave it around 40psi with those injectors and pump..maybe 45psi
Old Mar 18, 2010 | 07:44 PM
dsddcd's Avatar
60.7 PSIA
Old Mar 19, 2010 | 05:30 AM
m R g S r's Avatar
theres no need to go higher than 40psi unless you need more injector. and unless those are the ID1000's, I wouldn't be using high fuel pressures to make the injectors act like larger injectors.
Jaspah
Feb 4, 2017 12:12 PM
Chance S2K
May 14, 2015 07:16 AM
NightStalker
Jan 11, 2006 04:50 PM
cjb80
Nov 13, 2001 09:13 AM
