Fuel pump install
Old Jul 13, 2005 | 08:40 PM
slamar1's Avatar
Default Fuel pump install
Since 99% of you have done this for your turbo or SC, where can I find info on the procedure to do this. I know, I know, the service manual. Where else?
Old Jul 13, 2005 | 09:58 PM
AusS2000's Avatar
Um, the service manual on CD?
Even the Comptech SC instructions say refer to manual.
The proceedure is pretty simple. Start with 10 years of yoga training...
Seriously.
Relieve fuel pressure (pull ignition fuse and turn over engine)
Remove back panel above rear parcel shelf.
Remove parcel shelf
Remove access panel
Disconnect lines to pump
Undo 8 bolts and remove assembly
Disassemble and swap pump.
Reassemble in reverse order.
But I'd still invest in the manual before doing it. Also, I recently discovered that it is easier to remove the tray out through the trunk.
Old Jul 14, 2005 | 04:23 AM
Scorpion's Avatar
Make sure you are in a WELL ventalted area. I was high for 3 hours after doing the install, and sick for three days after words...and I had the garage door open
lg24
Jul 17, 2014 02:52 PM
RISLAR
Sep 19, 2008 11:37 AM
flexer
May 23, 2005 08:49 PM
lexar13
May 12, 2005 05:52 AM
Jip69
Feb 19, 2004 05:08 PM
