Is this a fuel pump problem?
Old Oct 31, 2007 | 01:45 AM
fperra's Avatar
Default Is this a fuel pump problem?
Well, my car is put away for the winter, but on my last ride I developed a problem and I think it related to a bad fuel pump (Walbro). Here are the symptoms:
Whenever the manifold vacuum gets close to 0, the car will not develop any power. I'm lucky to make 20 mph. It stumbles and misses and the AF ratio is all over the place on the lean side. Yet, with the car in neutral, it idles fine and revs throughout the rpm band fine. My first thought was that the GM 3 bar map was bad, so I swapped it out. But no, that wasn't it. So now I'm thinking fuel pump. What do you think? Should I order a new one?
Old Oct 31, 2007 | 03:24 AM
Sideways's Avatar
In my experience, the best way to spot a fuel pump going out is to watch the A/F on a dyno pull. They generally run out of fuel up top and go lean.
Old Oct 31, 2007 | 05:46 AM
Spec_Ops2087's Avatar
I just replaced my fuel pump because it was going bad. My symptoms were as follows:
Fuel pressure would slowly drop while driving car (would take an hour or 2 to get critical).
While idling, the pump would make a very loud whinning noise
When trying to accelerate (before boost) my A/F shot up to ~17-18
EGTs got much hotter (I was seeing 1400F+ when I hardly ever see 1300)
My idle fuel pressure with vacuum was only ~230kpa compared to a normal 320kpa
boostedap1s2
Jun 17, 2018 09:55 PM
shift9k
Aug 2, 2015 12:43 AM
Luis06s2k
Forced Induction For Sale
Mar 26, 2011 09:11 PM
elvir
Aug 31, 2010 11:50 AM
Spec_Ops2087
May 18, 2010 01:58 PM
