Fuel rail and fuel regulator
Old Oct 17, 2010 | 06:15 PM
Muscle Cars Blow's Avatar
Default Fuel rail and fuel regulator
Getting a full race kit with 1000ID injectors and a 255. Do I need a fuel rail and a regulator for 400whp goal?
Old Oct 17, 2010 | 06:25 PM
StocS2k's Avatar
y full race turbo kit?
and no not necessarily
Old Oct 17, 2010 | 06:36 PM
It's been recommended to me. I'd like to start with 400 and move towards 600. 400 obviously with stock motor and 600 once I build it and get tons of other parts.
Old Oct 17, 2010 | 06:59 PM
Angerman's Avatar
So 400-600whp range you say he doesn't need a fuel rail and fuel regulator for a daily driver? I don't think stock can handle that much for a daily beat on....
I told OP to look into Mase rather than full race for a newcomber turbo owner.
Old Oct 17, 2010 | 07:01 PM
S2K-F8's Avatar
I'm running that exact setup (full-race, ID1000's, 255 walbro) with the stock fuel rail and regulator, and I'm over 400hp.
Old Oct 17, 2010 | 07:08 PM
Angerman's Avatar
How? Why do I need a fuel regulator for a 320whp supercharger but a turbo above 400whp goal doesn't? To even run safe for a DD?
Old Oct 17, 2010 | 07:12 PM
S2K-F8's Avatar
Are you running a full stand alone like K-Pro or AEM?
Old Oct 17, 2010 | 07:16 PM
Angerman's Avatar
For me, I plan on running a piggyback Vortech FMU unit before I lower the pulley and then it will be a AEM Series 2 after I do more. But even then I plan on running a fuel regulator and also have a fuel rail handy with 725cc injectors.
What I don't understand is how he doesn't need a fuel pressure regulator and a fuel rail to make this thing reliable. These parts on this car at 72k miles aren't meant for this. I don't see why you recommend it being OK for a DD.
OP has a EMS I believe. Not sure if Series 2 or not.
Old Oct 17, 2010 | 07:23 PM
S2K-F8's Avatar
The stock fuel rail and regulator are good for over 500hp IIRC.
The reason you need a FPR with the Comptech or Vortech kit is due to the piggyback units they use. I had a Comptech kit, and the ESM that came with it hid boost from the ECU. You then need a FPR to add fuel since the ECU won't do it. You don't have to hide boost from a stand alone.
Old Oct 17, 2010 | 07:43 PM
spectacle's Avatar
Leave the stock rail and fpr alone unless you need them for fuel demands. Stock hardware can flow enough for anything you can make 93
