fuel smell?
Old Aug 13, 2009 | 09:40 PM
combats2000's Avatar
Default fuel smell?
im getting a fuel smell near the turbo when i stick my head in the engine bay..
nothign seems loose or licking.
i think im just being parinod
my a/f at idle is between 15-16
Old Aug 14, 2009 | 04:03 AM
BlitZs2000's Avatar
Why are you sticking your head in the engine bay!!?!
Old Aug 14, 2009 | 04:22 AM
kawi10r998cc's Avatar
Only way you'd get a fuel smell from the turbo is if you were extremely rich. If your idle is 15:1 that is not it. Check your fuel lines and the o-rings around the top and bottom of your fuel injectors...I had one of mine get pinched and whenever you'd switch on the ignition and the fuel pump would prime a little fuel would leak out of the first injector. I pulled the fuel rail and replaced the o-ring. Problem solved. Try that, switch on the ignition but don't start the engine (do it when cold) and smell and look for fuel.
Old Aug 14, 2009 | 08:05 AM
SFV_S2k's Avatar
Im getting the same smell!
I think it might be the oring by the fuel press. regulator.
Check everything !
Old Aug 14, 2009 | 12:12 PM
PowerPro's Avatar
When my car was naturally aspirated, I noticed a strong gasoline smell, but only as I drove. I checked under the hood, and there was my oil filler cap, where I had left it, near the cockpit air intake screen. I don't know how it made a fuel odor, but it stopped when I put it back on.
I'm with kawi10r998cc, pull the black plastic cover off the fuel rail and turn the key on but don't start it. Then do the look and sniff.
I don't know your turbo arrangement, but it's only handling air, exhaust and oil, in most cases. Unless you have an exhaust leak and your mixture is so rich it's got unburned gas in the exhaust, I don't see where you would get fuel odors from a turbo.
Old Aug 14, 2009 | 12:55 PM
sohc_mshue's Avatar
Are you smelling anywhere near the crankcase breather? Sometimes they can have a bit of a fuel smell from blowby.
CHIPPO
Aug 7, 2016 10:06 AM
lopez14
Mar 21, 2013 08:00 AM
Kvan_s2k
Dec 24, 2012 07:33 AM
MugenAP2
May 20, 2008 01:16 PM
