Full Blown turbo system
hey guy/girls i need more info about the full blown turbo kit stage 2. it looks very well made also. just have a few questions about it.
1. will it fit on a 06+ s2000?
2. what things do i have to relocate for it to fit?
3. is the AC fully functional?
4. what kind of turbo does it come with? (looking for the ball bearing precision 6262) or what ever you guys recommend. 410-430whp for low boost and 480+ whp for high boost is the goal.
5. can any exhaust fit on the downpipe?
6. it seems that its a tight fit to put a filter in the turbine ( can someone provide me pictures of the complete kit in the car installed)
7. does it come with pre-calibration map for the flashpro?
anyone running this kit can you give your opinion about the kit? did you regret it and wished you went with ptuning or mase or other turbo system?
any info would be appreciated. thanks guys..i've done research already just need more so i can decide which kit to go to...
Here you go: Grandmasterkans build. His car is an 06. He also has a set of my A/c lines to re route them to a safer and cleaner way. https://www.s2ki.com/s2000/topic/853...n-turbo-build/
They say you can run a small hks filter. Have yet to see a picture with a filter. And they do not include maps as flash pro is easy to use and you can make your own startup map in 5 mins.
