Fullblown Radiator Questions
i had a pin hole leak on one of the welds tiged it my self. glued the stock foam piece to the core support and notch the crap out of the fans and put weather stripping on the right fan threw on a greddy cap and was good to go other than some polishing
I had to bend my lower tabs for my fans also.. And my cap needed pliars to be removed the first couple times.. Now that the aluminum has gotten worn down I can remove it by hand. I never tried to put the lower plastics on so I can't help there. All in all for the price ($20ish more than oem) I'm happy
The only thing I had to do was play with the fan shroud spacing a little bit and cut a notch out for my after cooler to fit for my Comptech kit because everything sticks out further. Everything else was plug and play. I was impressed how easy it all went together.
Not sure why you bothered to remove the under tray? It can all be done from above.
For those of you with issues.....contact LJ. He's an awesome guy to deal with, I'm lucky enough to be ~40min away from Full Blown and have dealt with them a fair amount. Awesome customer service.
I wasn't aware of these issues. Please contact me directly if you have any questions or concerns. Fullblownmotors@gmail.com thanks guys
Originally Posted by mr-pitts' timestamp='1372740592' post='22642346
[quote name='FullBlown' timestamp='1372707069' post='22641466']
[/quote]
It's too late to worry about the concerns,I've had it powder coated to cover the awfull finish that it came out of the box with. The dealer in question cannot be held responsible for the condition that it came out of a sealed box in.I was passed onto to you with my concerns and when I didn't receive a reply I took necessary action in order to make the best of a bad part and did as I said above.If I have any other issues with it I will just throw it away and replace it with something else.
This is the second Rad with the same damage,I thought I had dented the top tank on my first rad so didn't think anymore about it,then I let a friend have it because he needed one quick.When the second one arrived with the same damage in the same area I emailed you and as said above I got no reply.It came out of the box damaged with all the packing intact,so forgive me second guessing but I would say it was damaged at source.
