Garrett GTX30R
Garrett GTX30R
Anyone running the GTX30r on there car and what numbers are you making on pump gas?
I currently have the GTX35R but i want to have a quicker spool time, and still want to be in the 500 range on pump gas..
Thanks guys.
Thanks guys.
Go with the gtx3576r. The gtx3076r is a mismatched turbo. The gtx3576r is have the same spool time as the gtx3076r just with more power.
The gtx3076r should be skipped. If you want a quick spooling turbo go for a gtx3071r the. To a gtx3576r then to a gtx3582r.
http://www.enginebasics.com/Advanced...0GTX3576R.html
What compressor size are you running on your GTX35R?
The problem with the gtx3076r is that the turbine is too small for the high flowing gtx 76mm wheel. That's why a gtx3576r does not loose any spool time over the gtx3076r plus the gtx3576r also make much more power than a gtx3076r.
