Garrett warranty ?
Old Jun 15, 2012 | 01:50 PM
red@9k's Avatar
Yup u do need a restrictor for GT-series turbos from Garrett. I have .035 from ATP turbo and mine is still fine. Thats your problem
s2kseven's Avatar
how do you know if its real garrett?
chinese garrett?
Old Jun 15, 2012 | 02:42 PM
jpetch05's Avatar
I got it through afi turbo. And they said don't use one (resteictor) dammit. It feels/looks real. But yeah. Thats the problem for sure. I just talked to my bud who deals turbos. Okay then. Thanks guys.
Old Jun 15, 2012 | 03:08 PM
spdracerut's Avatar
Originally Posted by camuman
dont agree. his turbo failed from lack of restrictor plain and simple. many on the site have drained to top of pan with zero problems, myself included. the pan doesnt fill that much with oil, esp when car is running. however, oil pressure has claimed many turbos on this site.
Just because it works okay doesn't mean it is good for all operating conditions. If you talk to Borg Warner, Garrett, MHI, IHI, Holset, every single one of them will tell you the proper oil drain method is to have the oil drain above the oil level. They will not warrenty product if it is not.
You can get away for a pretty long time with doing something improper, such as this turbo lasting as long as it did with the improper oil feed, but it will reduce the life of the components overall.
Old Jun 15, 2012 | 04:10 PM
camuman's Avatar
There is no way the oil level is that high when the car is running. That was my point and you missed it completely.
Old Jun 15, 2012 | 04:15 PM
herecomesboost's Avatar
Originally Posted by riceball777
your turbo is blow because you are not useing the correct .035 restrictor. I have clost to 80,000 miles on my gt35r on my evo and it has no shaft play and still runs like new.
That's impressive for an aftermarket turbo
Old Jun 15, 2012 | 09:03 PM
spdracerut's Avatar
How about when pulling a lot of Gs? It's kinda like detonation... a little bit of detonation here and there will slowly kill an engine. Or momentary bits of oil starvation will slowly kill the bearings in your engine. The damage won't show up immediately as it's not catastrophic, but it will do damage.
Old Jun 15, 2012 | 09:05 PM
spdracerut's Avatar
It's based on OEM qualified Garrett turbo for Nissan. It should be perfectly reliable. Why wouldn't it be?
Old Jun 16, 2012 | 04:43 AM
camuman's Avatar
Most of us don't stab the brakes hard and long enough for that momentary slosh of oil to hit the front highest point of the pan that holds the oil drain. I mean listen. People road race turbo s2ks. People street drive them. The only time anyone has trashed a turbo from oil problems is lack of a restrictor or a wrong restrictor. Plain and simple.
Old Jun 16, 2012 | 05:52 AM
jpetch05's Avatar
Originally Posted by spdracerut' timestamp='1339823004' post='21786179
[quote name='camuman' timestamp='1339805428' post='21785717']
[/quote]
Agree. It's not impossible by any means at all. But I haven't seen it cause a failure yet.
