gauges\ sensors
AFR is a MUST - #1 warning sign before you blow some sh*t up
BOOST - Perfect to show any possible belt slip, leaks, etc, tied in for a close second
Oil PRESSURE - your SC is spinning pretty darn fast, i wouldnt want a drop in oil pressure to cause my blower to slice grind its self apart. ^tied with the boost
Optional-
Oil temp- not too much of a necessity with a SC as they dont get within a mile of the heat that a turbo gets, not much of a necessity
water temp- also not too much of a necessity, but its useful too
Optional-
Unless he is opting for the self lubed blower, the wideband & boost should be enough
Or an AEM serial gauge...
