gauges\ sensors
Old Aug 8, 2011 | 07:13 AM
hariku821's Avatar
Default gauges\ sensors
I will be running an SOS stage 2 kit around 12-14psi with AEM EMS and I am wondering what gauges I should buy. Oil temp, fuel pressure, boost , etc..... I am not sure what I really need..
Old Aug 8, 2011 | 08:26 AM
s2konroids's Avatar
As many as you can afford.
AFR as a minimum.
But if you had to break it down to the 3 essential ones...AFR, oil temp and boost IMO
Old Aug 8, 2011 | 09:03 AM
BrockB's Avatar
3? Wideband, boost, oil temp or oil pressure.
Old Aug 8, 2011 | 09:47 AM
hariku821's Avatar
I have the funds to get as many as I need but I don't want a lot of clutter or something I really do not need.
Old Aug 8, 2011 | 09:53 AM
Importedpower's Avatar
AFR is a MUST - #1 warning sign before you blow some sh*t up
BOOST - Perfect to show any possible belt slip, leaks, etc, tied in for a close second
Oil PRESSURE - your SC is spinning pretty darn fast, i wouldnt want a drop in oil pressure to cause my blower to slice grind its self apart. ^tied with the boost
Optional-
Oil temp- not too much of a necessity with a SC as they dont get within a mile of the heat that a turbo gets, not much of a necessity
water temp- also not too much of a necessity, but its useful too
Old Aug 8, 2011 | 09:58 AM
spapdx's Avatar
Unless he is opting for the self lubed blower, the wideband & boost should be enough
Or an AEM serial gauge...
Old Aug 8, 2011 | 10:53 AM
DFWs2k's Avatar
Just 1- Serial gauge
Old Aug 8, 2011 | 10:59 AM
S2k.berto's Avatar
get the plx digital gauge. if you don't want all the clutter of every gauge it can read all nearly every option kind of pricey
Old Aug 8, 2011 | 11:11 AM
vadik_s2k's Avatar
What are the A/F options for dbw guys? Stand alone aem wideband lambda with gauge?
Old Aug 8, 2011 | 07:44 PM
miguel329's Avatar
Does tunerview work on a o6 wit flashpro? Loved it in my hatch hate all those guages in my car.
