Geddy Turbo install
Old Dec 31, 2007 | 02:19 PM
AlabamaS2000fan's Avatar
Default Geddy Turbo install
Well I have surcome to the FI gods and bought a Greddy. After many many hours under and over the car, I finally am about 90% complete on the install. I will be intalling the EManage, plugs, oil, tomorrow and checking everything before I fire it up. I need help on the Emanage. I noticed a couple of other plugs on the wiring harness and needed some help on where those get pluged into.
Also where are most people putting the unit? The wiring harness is so big that I can see putting it on the passanger side, but I have an aftermarket deck and do not have much room to get the wires over the tunnel?
Also I had some help with getting the O2 sensor disconnected and the person that did it disconnected both sensors. How do i know which sensor plugs into which harness????
Old Dec 31, 2007 | 05:26 PM
S2Kart's Avatar
-Don't exactly remember but I thought all the new connectors will plug into the stock ECU, and all the stock connectors go to the ULT. They are all keyed so there is only one way to hook it up.
-The front 02 sensor (before the cat) has a white wire and the back sensor (in the cat) has a white/red wire. The connectors are different so they can't be switched.
-I put the ULT in the dash at the bottom left by coiling up the extra harness wire and wire tying up under the dash. I can still pull the ULT out as needed though.
Old Dec 31, 2007 | 07:29 PM
Thanks for the info. Actually on the sensors, they can be switched. Both connectors are the same on both sensors...
Old Dec 31, 2007 | 08:26 PM
MuckaLun's Avatar
i'm also trying to install the ULT with the plug and play..
Alabama, what did you do with the 3 loose wires in the plug and play harness (Red, Black, Purple w/ Yellow strip)? I'm new at this and not sure if i should leave them out...
thx
Old Dec 31, 2007 | 10:32 PM
neptuner's Avatar
I got the long harness and put the ULT on the floor behind the drivers seat. Ran the harness in the sill beside the drivers seat. Fits nicely and is easy to access.
Old Jan 1, 2008 | 05:55 AM
S2Kart's Avatar
Thats probably the best place for it
Old Jan 1, 2008 | 03:05 PM
Muchalun...I have not done anything yet. I will be finishing the project on Saturday. Since the module comes with the cords being so long, I will probably put it on the passanger side or in the driverside kick panel with the wires routed and zip tied throughout.
Old Jan 14, 2009 | 02:10 PM
Josh_With_The_S2K's Avatar
pictures?
Forgottens2k
Dec 11, 2015 03:34 AM
dylanrush
Nov 12, 2013 05:35 AM
Fasterthanyourmoms
Dec 15, 2011 10:58 AM
jaundice
Feb 23, 2010 08:30 AM
syellow
Nov 14, 2007 01:11 PM
