Getting AEM Serial gauge to read boost in psi....
Old Jan 2, 2012 | 01:54 PM
Wydget's Avatar
Default Getting AEM Serial gauge to read boost in psi....
I know it's been asked before but nothing really very helpful. Has anyone had success in getting the gauge to read boost in psi instead of Kpa. Screenshots or a step by step would be very helpful. I'm trying to see if I'm getting the full 12 psi from my supercharger... Thanks in advanced.
Old Jan 2, 2012 | 03:15 PM
neeman77's Avatar
I did not find a great answer when I made this happen years ago so I manually converted the kpa to psi and entered the values in the serial gauge program for the appropriate voltage.
Old Jan 2, 2012 | 03:53 PM
camuman's Avatar
Change the units in your aem ems software. Then psi will show psi and not kpa on serial gauge.
Even though ur ems will say psi change to kpa hit apply then psi and apply. Should fix it.
Old Jan 2, 2012 | 04:04 PM
gsx2004's Avatar
same thing i did in the aempro software. just went to options>units>there u go
Old Jan 2, 2012 | 05:01 PM
Wydget's Avatar
I'll try this when I get off work in the morning. Thanks guys. Would I have to change anything through the gauge software??
Old Jan 3, 2012 | 01:54 PM
Wydget's Avatar
Just tried this and it did not work. Under options, there isn't a "units". Under "Configure" there is a tab says "Units..." then it goes to "Unit Preferences" which lets me choose "Load Units" There I tried changing from PSI to KPA, hit "apply",then back to PSI, hit "apply" and save. Then I reconnected the serial gauge and started the car. The gauge is still reading in Kpa.
Old Jan 3, 2012 | 06:41 PM
camuman's Avatar
So on ur serial gauge when u select psi it shows a large number ?
Very weird. Lemme check again. I thougt that gauge just shows what aem sends it.
Old Jan 3, 2012 | 07:02 PM
Wydget's Avatar
It's under the "PEA" which is what I believe the tuner stated was boost. But it starts at 14-19. I've got a 12 psi pulley but was only able to get 10 psi when I was on the dyno. I still have yet to figure it out what is wrong with that but I do want to monitor the boost and not have to worry about trying to calculate the right percentage.
Old Jan 3, 2012 | 07:04 PM
camuman's Avatar
What map sensor are u using? Serial gauge software needs specific map sensor calcs to work right.
Old Jan 3, 2012 | 10:24 PM
Wydget's Avatar
SOS 3 bar map sensor. So I made the change in the ems software, do I have to change something in the gauge software also???
