Getting AEM Serial gauge to read boost in psi....
Old Jan 4, 2012 | 09:31 PM
Wydget's Avatar
bump!!
Old Jan 5, 2012 | 04:47 AM
camuman's Avatar
When u built ur gauge calc file which map sensor did u select? This has to be the reason why urs doesn't work right.
Old Jan 5, 2012 | 07:47 AM
Wydget's Avatar
That I don't know. My tuner installed and set up the gauge.
Old Jan 6, 2012 | 12:49 PM
Wydget's Avatar
Tuner stated it is using base cal file...
Old Jan 8, 2012 | 04:27 PM
Wydget's Avatar
anyone??
Old Jan 8, 2012 | 04:58 PM
camuman's Avatar
Originally Posted by Wydget
anyone??
He used wrong calc file. Well not wrong but he didn't fix it for ur map sensor.call SOS and ask them what info needs to be changed in pro gauge calc file to make it read right.
Old Jan 9, 2012 | 12:53 AM
Wydget's Avatar
Ok, cool. What is gonna read under in the gaugepro for boost?
Old Jan 9, 2012 | 11:42 AM
TerminatioN's Avatar
I had to do this awhile back. Off the top of my head, here is what you need to do:
In AEMPro:
  • Go to view telemetry setup.
  • Click on the show info button.
  • Find the min and max values for engine load.
In Pro Gauge:
  • Open the lookup table for boost.
  • Click on the auto fill button.
  • Next you will need to enter the start cell (Item number), stop cell (item number), and the start and end values.
  • The start cell should be 0, and the start value for that cell should be the "min" value you found via AEMPro.
  • The end cell should be 255, and the end value for that cell should be the "max" value you found via AEMPro.
  • Then click fill table.
Done.
Effectively you're recalibrating the gauge so that the first value it reads is the lowest value ("min" value) the EMS will send, and the last value/cell for the gauge will be the largest value the EMS will send ("max" value), and the fill button calculates everything in between for you.
As long as your EMS is already set to PSI, this should work.
I will try and help if you have any problems, but its been awhile since I've done this.
Old Jan 10, 2012 | 04:30 PM
Wydget's Avatar
Now I can't get the gauge to connect to my laptop. I was doing it fine a few days ago... I don't know what happened..
Old Jan 11, 2012 | 08:31 PM
Wydget's Avatar
Anyone have any idea on why its not connecting anymore?
