Getting AEM Serial gauge to read boost in psi....
Old Jan 11, 2012 | 08:42 PM
  #21
TerminatioN's Avatar
Originally Posted by Wydget
Anyone have any idea on why its not connecting anymore?
Make sure you have the gauge completely off (ie absolutely no power to it... I take the key completely out to insure this), and open the software and get it to start trying to connect (ie the "connecting to gauge" window/popup should be open) and then put the key in and turn to on and let the gauge power up.
This is crucial. The first time I tried connecting to my gauge it took me a long time to figure this out (even though it clearly says this in the instructions). This is the only way it will work. If the gauge is already on and you try to connect, it will not work. Also make sure that if you have two serial gauges that they aren't connected (ie "daisy chained") to each other. If I remember correctly that is another thing that could cause problems connecting.
Other than that I can't think of anything. Good luck.
Old Jan 11, 2012 | 09:00 PM
  #22
Wydget's Avatar
My serial to USB has led lights to indicate connection on the serial connector? Does that include the power I should disconnect. I had it connecting a few days back, I honestly don't know what's changed.
Old Jan 11, 2012 | 09:11 PM
  #23
Maybe. Try setting the software to connect and then plugging in the cable and turning the key to on.
Old Jan 11, 2012 | 09:19 PM
  #24
Wydget's Avatar
I got frustrated yesterday after getting a couple of cal files from another member on here and not being able to try them out. I will try again first thing in the morning, hopefully it works.
Old Jan 12, 2012 | 09:19 AM
  #25
Wydget's Avatar
So I contacted AEM customer service but it didn't help. The only thing they told me was to check the connectors. Looks like I'm headed back to the tech store for another female to female connector. I really want this to start working!!
UH-60DRIVER
Jan 27, 2017 02:22 PM
UH-60DRIVER
Jan 26, 2017 06:49 PM
Wydget
Jan 2, 2012 12:59 PM
JuicedS2K
May 10, 2010 02:42 PM
s2000Junky
May 8, 2008 10:24 AM
