Getting boosted and need help
Old Jun 20, 2006 | 09:43 PM
S2K:-)'s Avatar
Default Getting boosted and need help
Ok as some of you know, I'm getting the inline pro kit installed right now. I have been READING AND READING AND READING to learn all I can. Now I just have a few questions.
Let me start with this: I'm not running an EMS or head gasket for the time being, but I'm only running 8psi. I have the black box from the comptech S/C as my piggy back and I'm running a uego gauge to watch my a/f to make sure everything is ok and I plan to get the EMS by the end of the year.
1.) What kind of things do I need to look out for on an everyday basis? (sounds or sights)
2.) What things I should be monitoring? (parts, gauges or signs)
3.) What should I make sure my A/F is at... what range should it stay in.
4.) Am I looking at a potential problem with no EMS?
Please add anything to my list that you think I should watch out for or take notice in.
Thank you all for your time,
-Nick
Old Jun 20, 2006 | 10:00 PM
kane.s2k's Avatar
It would be good to state what are you running if you aren't running the EMS.
Low load, 14:1
Pre-boost, 13:1 a/f's
Boost, 11's & 12's
Your biggest safety factor comes from timing control however I don't think you have the means to control that do you? The e-manage is not very good at it to say the least.
Old Jun 20, 2006 | 10:09 PM
S2K:-)'s Avatar
Low load, 14:1
Boost, 11's & 12's
I'm running the comptech black box as my piggy back.
also, what do you mean by safety factor comes from timing control... How can I make it safer... Pretend you're explaining all of this to a 3 year old, that'll help me out.
Old Jun 20, 2006 | 10:14 PM
kane.s2k's Avatar
So I am assuming comptech black box to control the timing and matted to an FMU.
You basically cannot do anything to make it safer. You are at the mercy of the programming in the comptech box and fuel delivery should be slightly adjustable but not significantly. John @ inlinepro had V-AFC to add some fuel to it and do a tiny bit of timing and he ran like that for a while.
Old Jun 20, 2006 | 10:51 PM
S2K:-)'s Avatar
Ya that's what I am doing
Well I'm not going to get a vafc or anything because I could spend the additional $200ish toward my ems instead... Any other hints?
Old Jun 20, 2006 | 11:16 PM
kane.s2k's Avatar
Nope, honestly there is nothing else you can do. If it worries you that much, hold off on the install if you can. Otherwise, just go for it
Old Jun 21, 2006 | 03:18 AM
AllStock27's Avatar
does the comptech black box control fuel too? i thought only timing and the fmu controls the fuel?
Old Jun 21, 2006 | 05:17 AM
OGPackin's Avatar
Exhaust leak or oil leaks would probably something you need to look out for. Also oil presure and water temps are two very important things to keep an eye on.
Water temp, Oil presure, A/F, Boost
Make sure it stays in the green on the gauge...
IMHO i would wait to get the AEM to be safe. Your spending all that money and you wont be able to get the most out of it if you cant tune it properly. just my .02
Old Jun 21, 2006 | 05:22 AM
jakub2000's Avatar
^ I agree with all points..turbo on a car like this is not a cheap think, so If you can afford it, better wait a few months or borrow money for the EMS.
Old Jun 21, 2006 | 06:31 AM
S2K:-)'s Avatar
[QUOTE=AllStock27,Jun 21 2006, 07:18 AM] does the comptech black box control fuel too?
