Getting ready for FI going to do a lot of internal
Old Jun 21, 2006 | 09:15 PM
xdavieexx's Avatar
Default Getting ready for FI going to do a lot of internal
My friend who is a toyota guy, and owns a very nice supra. He never really delt with Hondas, but i've asked him to help me out with building the internals for my motor to get it ready for a custom turbo kit we will build. It will probably be around 300-400 whp. As for psi im not sure how much we will run but probably around 10-14. Not sure of what turbo we're going with yet. I would like you guys to help me out with choosing some parts for internals.
retainers
springs
rods
pistons if im going to lower compression
etc etc.
thanks and i hope to keep you guys updated once we start working on the car
Old Jun 22, 2006 | 12:51 PM
mob_blue's Avatar
im almost 100% positive you can hit mid 300s on like 8 lbs of boost...safe to do that on stock internals
Old Jun 22, 2006 | 01:12 PM
John_Z's Avatar
Unless you have money burning a hole in your pocket, you can easily get 300-400rwhp on stock internals.
You'll want to drop your compression on anything above 10psi by using a thicker headgasket or pistons.
Old Jun 22, 2006 | 02:37 PM
xdavieexx's Avatar
i will probably go with 2 mm headgasket. I just want to make the motor stronger while im at it. Plus he can get me great deals on what i would need and since we are doing this ourselves(he works on it and im the helper monkey ) no labor charges. This is why i need to a list of parts so i can research further to see which will be the most compatible with my set up.
Old Jun 22, 2006 | 02:41 PM
passmans2kny's Avatar
2mm head gasket is def enough for 300 to 400 hp, best internals imo super tech springs, retainers, cp pistons pauter rods
Old Jun 22, 2006 | 03:26 PM
kane.s2k's Avatar
Supertech valves, valve springs, retainers if you are building the head. 2mm/3mm head gasket if you want to do it the cost effective way. CP pistons and pauter rods for sure.
You cannot use OEM sleeves with most aftermarket pistons. I have my AEBs Sleeved block for sale which is at an 89mm bore and already honed. Sleev install was done by Z10 engineering and the bore/hone was done by benson sleeves.
McFab
Mar 17, 2013 03:48 PM
rpm whor
Jan 22, 2013 10:29 AM
reds2k2000
Mar 24, 2009 07:18 PM
Polimangas
Sep 11, 2006 10:44 PM
A769
Jul 10, 2006 11:17 PM
