GM Boost Control Solenoid and Switch
Old Aug 28, 2006 | 08:54 AM
geists2k's Avatar
Default GM Boost Control Solenoid and Switch
For those using the GM boost control solenoid, what did you use for a switch and where did you mount it? Any pics?
I already have the wiring end worked out with the AEM EMS, I just need an idea of what to get for a switch and where to put it in the car.
I need to get this figured out before I get tuned this Friday
Thanks.
Old Aug 28, 2006 | 09:08 AM
XclusiveAutosports's Avatar
I can't help you out with installing it as I still haven't gotten mine in, but you can order it from here... http://automotivespeed.com/product_i...roducts_id=209
Old Aug 28, 2006 | 09:16 AM
geists2k's Avatar
^^ No, I already have the GM boost control solenoid installed and hooked up in my engine bay and ready to be wired into my EMS.
What I'm talking about is what do you use for the actual switch inside the cockpit of the car and where is a good place to mount it?
Old Aug 28, 2006 | 03:24 PM
timg's Avatar
No switch here. Mine runs 100% of the time and is tuned for max power and boost on pump gas. If I want less power, I simply don't press as hard on the gas. More power = race gas and new parts = retuning = uploading a different/new map.
Tim
Old Aug 28, 2006 | 04:01 PM
geists2k's Avatar
Tim
Thanks Tim, but my tuner thinks differently and he works for AEM so I'm pretty sure of his advice.
Anyone have any thoughts on my original post?
Old Aug 28, 2006 | 07:40 PM
Kwando's Avatar
i am getting a boost control solenoid also... info on wiring it please... thx
Old Aug 28, 2006 | 08:24 PM
kane.s2k's Avatar
You can use any on/off switch from radio shack. I don't use one myself but you can do that if you'd like.
Just hook up a + and the GM solenoid to an available pulse-width output. Use the D connector if you can or have it.
Old Aug 28, 2006 | 11:33 PM
hulk_null's Avatar
Spammer
thanks dear
TerminatioN
Jun 6, 2012 01:23 PM
03silver2000
Apr 28, 2008 06:28 PM
jakub2000
Jun 19, 2006 06:23 AM
AusS2000
Aug 27, 2005 06:13 AM
jakub2000
Jul 19, 2005 02:53 AM
