GM BOOST SOLENOID & Injectors
Old May 11, 2007 | 02:06 AM
fadiss2k's Avatar
Default GM BOOST SOLENOID & Injectors
From reading posts, i have come to the conclusion that on the GM boost solenoid you hook up one wire(doesnt matter which) to a 12v source(ignition) and the other wire i am not sure about. I believe you hook it up to pin D16 on an AEM EMS 1052. Is this right? Also, does anyone have a pic of that? Maybe with the wire installed, but if not just the pin! Also my car started making a really loud ticking noise that sounds like it is coming from the injectors. They are 675cc injectors that you can get from inline pro. Is this normal or should i be worried? Any help would be greatly appreciated!
Thanks
Fadi
Old May 11, 2007 | 06:09 AM
boostedAT9K's Avatar
i have the same ticking. i also have inlinepro 880 cc injectors. in my case it does it at random times.
Old May 12, 2007 | 04:57 PM
fadiss2k's Avatar
I hope it is not something bad. I have had the turbo kit on only 2 weeks and haven't really drove it much because it is not tuned, but this noise started a few days ago. It goes away sometimes and sometimes it just wont go away!
Old May 13, 2007 | 01:00 AM
timg's Avatar
Depending on how your boost control is setup, the boost control solenoid may click at idle.
Tim
Old May 13, 2007 | 04:10 AM
fadiss2k's Avatar
It is not hooked up yet though. I need to figure out if d16 is the right pin and if anyone has a diagram for it. I tried lookin on aems site...but i cannot get the diagram page to come up.
Old May 13, 2007 | 08:50 PM
fadiss2k's Avatar
nobody with a gm boost solenoid wanna help out? I need to finish this by tomorrow so i can be ready to tune on tuesday morning!
corners2
Jun 15, 2013 05:50 PM
ctb2024
Oct 19, 2008 09:08 AM
sbrodacz
Sep 12, 2008 06:58 PM
slamar1
Aug 27, 2005 10:41 AM
Doss
Feb 22, 2005 03:00 PM
