goin emanage
Old Jul 11, 2012 | 10:04 PM
s2k manic's Avatar
Default goin emanage
00 ap1 comptech supercharger with after cooler 4.2 pulley 6psi rrfpr test pipe magnaflow mufflers vafc2 lowering vtec to 4600 was hearing detonation around 5000k lower vetc helped that aem water meth plx wide band looking to clean up afr right now pre vetc 11.7 vetc 12.9 to redline 12.3 12.5 so thats what ive got goin on some times in vtec part throttle im seeing 10.0 afr so hopefully i can clean some of the fat spots so any help, advice would be greatly appreciated please help thanks
Old Jul 12, 2012 | 03:48 AM
Manny2587's Avatar
Vtec
Old Jul 12, 2012 | 05:14 AM
camuman's Avatar
aem or krpo. bleh to eman.
Old Jul 12, 2012 | 07:45 AM
Deception's Avatar
Old Jul 12, 2012 | 10:39 AM
CD7SirAccord's Avatar
With everyone else, get new injectors ditch the ESM and rising rate fuel pressure regulator and get a standalone.
Old Jul 12, 2012 | 01:15 PM
jordannn93's Avatar
If your on a budget get a used aem series 1 and Evans e tune
Old Jul 12, 2012 | 08:59 PM
s2k manic's Avatar
can anyone provide helpful information its what i have and can afford so if you have any tuning advice i would appreciate it if not than never mind thanks
Old Jul 13, 2012 | 05:08 AM
camuman's Avatar
only two people i know of did well tuning eman equipped cars. one doesnt post on here anymore and the other i dont think tunes them anymore. contact local tuners, ask if they are proficient with it, and then go from there.
Old Jul 13, 2012 | 06:54 AM
s2konroids's Avatar
I'm confused as to what you are actually asking.
Old Jul 13, 2012 | 09:15 AM
s2k manic's Avatar
for starters can i use windows 7 or will i have to get a device with xp? can i use the wide band output from my plx module to feed the emanage wide band signal. the harness is a greddy anything i need to change to make this work or just plug it in and start setup and what does the two wire connector with green red wire and white with red tracer go to?
