Going back to NA question
Old Dec 12, 2014 | 09:54 AM
liquidgsr's Avatar
Default Going back to NA question
So I have been thinking a little. For the time being I might just get a swap and put it in to drive the car again and for go the turbo setup. Here is my question. My fuel system has the Fullblown complete fuel system with the -10 Feed and -8 drain, FB fuel filter, and Fuel regulator, dual hanger with Dual 340s, feeding a set of ID2000s. Can I run a NA header to my 3" exhaust and have it tuned or will I need to swap all this stuff out?
Old Dec 12, 2014 | 10:08 AM
s2000Junky's Avatar
I dont see any reason why you couldnt run it fine as is, minus the 2000cc injectors. I would swap these out. Just pick up a good set of used oem injectors for now and dial in the fuel pressure. It will run a lot better.
Old Dec 12, 2014 | 11:19 AM
liquidgsr's Avatar
Problem is the shop I had taken it to cut the factory connections off for the injectors and sodderd the ID2000 injectors.
Old Dec 12, 2014 | 11:25 AM
s2000Junky's Avatar
That sucks, i always try and go with pnp. Id cut them off and solder the oem back on.
Old Dec 12, 2014 | 12:35 PM
KaNgArOo's Avatar
WHY!! I don't think i can every go back to N/A on this car ever again. Unless it was for an LS7 Swap.
Old Dec 12, 2014 | 06:53 PM
camuman's Avatar
LOL
Old Dec 12, 2014 | 08:56 PM
riceball777's Avatar
Yes you can Dyno your car na and it will be fine. The main issue is that your car will drive rought on 91/93 octane with the 2000cc injectors. I suggest you just run the stock injectors.
nguyen365
Dec 28, 2017 05:40 AM
liquidgsr
Jul 31, 2016 09:11 AM
nextinstant39
Forced Induction For Sale
Dec 15, 2011 08:09 PM
JohnnyP912
Nov 28, 2009 12:59 PM
otbs2k
Oct 27, 2009 09:16 AM
