going back to stock for now
Old May 23, 2010 | 01:34 PM
roscoe's Avatar
Default going back to stock for now
so i pulled off my greddy kit and returned car back to stock and i can't start it for some reason any idea?..i had the car parked for 2 months shes cranks but will not start so im kind a stumped right now any help would be greatly appreciated..thanks
roscoe
Old May 23, 2010 | 03:03 PM
s2kswe's Avatar
Do you honestly think we can sit here and guess what sympthoms you are seeing and then come up with some grand solution? Post some basic information like if the car has spark, fuel etc and we might be able to help.
Maybe some info about what you did to enginemanagement, injectors etc aswell.
Old May 23, 2010 | 03:25 PM
roscoe's Avatar
injectors are back to stock ones emanage was removed and everything is back to stock..now do i have to retune the car? what i have right now is the stock ecu. thanks. theres fuel and of course car has spark or else it would not have turned over..engine cranks but will not start..
Old May 23, 2010 | 06:33 PM
mnr12's Avatar
Maybe you flooded the plugs?
Old May 23, 2010 | 06:55 PM
roscoe's Avatar
what do you mean by flooding the plugs?
Old May 23, 2010 | 07:08 PM
ekoms31's Avatar
try jumping the battery. if the car was sitting for 2 months the battery probably doesn't have enough power.
Old May 23, 2010 | 07:19 PM
Andrewap1's Avatar
turning over doesn't mean there is fuel and spark.
the motor turns over from the starter..
pull your plugs, if theyre soaking wet with fuel, you have no spark.
if they aren't soaked, turn the motor over with the plugs out and the coils out, see if you can smell some fuel.
Are you using YOUR factory ECU that came with the car? Could be that your car ECU needs to relearn your immobilizer.
Old May 23, 2010 | 07:43 PM
roscoe's Avatar
thanks i'll try that tomorrow
Old May 23, 2010 | 07:44 PM
roscoe's Avatar
already did that brotha nothing still...
Old May 24, 2010 | 03:19 AM
lotus7racer's Avatar
Motor turns, does not mean there is spark.
Your engine has no spark!!
