going back to stock for now
Old May 24, 2010 | 05:08 AM
HMFIC's Avatar
i did this once... and realized that i was using my extra key that wasn't sync'd with my oem ecu lol... the car would just crank and crank and i couldn't figure out why... then the wifey asked why i was using the spare key...i just wanted to smack the hell outta myself...
Old May 24, 2010 | 05:16 AM
roscoe's Avatar
wow but naw man i used my master key..spares sits in my house. i'll pull the plugs and coils out today and see but thanks everyone for your input..
Old May 24, 2010 | 06:09 AM
lotus7racer's Avatar
Roscoe---if any of the coil is bad, the engine will start but missing.
If no spark at all, yes could be your security key, crank sensor, cam sensor.
Do you have a CEL?
That's another thing you did not confirm to us.
Old May 24, 2010 | 11:27 AM
roscoe's Avatar
no cell light but i will check for the coils and flooding in the injectors..thanks bro
Old May 24, 2010 | 07:40 PM
roscoe's Avatar
so removed coils and there were no spark but injectors were good..might be spark plugs then?..
Old May 24, 2010 | 07:45 PM
Andrewap1's Avatar
doubtful if there is not spark at all on any of the plugs.
may have a bigger problem.
kind of sounds like your the immobilizer in your key has done its job, immobilized you. Lol
Or you just have a bigger problem causing your car to not spark.
Old May 24, 2010 | 08:25 PM
AusS2000's Avatar
Originally Posted by roscoe,May 24 2010, 09:25 AM
theres fuel and of course car has spark or else it would not have turned over..engine cranks but will not start..
Not true. If a car has no spark it will still turn over, just not start.
To start a car you need fuel (petrol pump working, injectors working), spark (power to coils, coils firing on time) and a working starter motor (to get the engine to turn over). Without fuel and spark the engine will happily spin on the starter motor until the battery is depleted.
My guess is that when you removed the e-manage you didn't correctly reconnect the ignition leads. Was it a plug and play harness? Did you remove the harness and plug the original loom back into the ECU?
Old May 26, 2010 | 02:26 AM
roscoe's Avatar
yes i did plug everything back into the stock ecu and everything is connected..i do have fuel going to injectors and i do have spark..i might have to just recheck all my wirings again..and it was the plug n play..i have power going to all the relay also so what else could it have been?..thanks
ericss2kturbod
Jan 15, 2013 08:20 AM
RedSunS2K
Oct 29, 2011 01:47 PM
lvd1102
Jan 9, 2010 05:51 PM
s800
Sep 30, 2008 09:22 PM
ChefJ
Feb 20, 2007 01:31 PM
