Going into Boost, car runs lean
Old Dec 18, 2009 | 08:41 AM
jari8378's Avatar
Default Going into Boost, car runs lean
So i have this problem, not sure whats causing it.
My car idle's fine. No wierd or abnormal sounds. When i start going into boost, my car AFR's immediately go from about mid 12's to super lean 17:1.
This immediate change happens around 2-3psi.
Old Dec 18, 2009 | 08:43 AM
JoeyBalls's Avatar
Bad wideband maybe?
Check ur plugs
Old Dec 18, 2009 | 08:49 AM
jari8378's Avatar
I was thinking about replacing the plugs they are a bit dated,
Why would the WB be causing the issue. You can imediately feel the car lean out.
Old Dec 18, 2009 | 08:50 AM
spectacle's Avatar
Does the wideband read lean but the car still pulls? An AFR that high would cause the motor to damn near blowup transitioning into boost so sounds like something is up with your wideband.
This just start happening? Any mods around the first occurance?
Old Dec 18, 2009 | 09:03 AM
jari8378's Avatar
This just started happening...
Today on the way to work.
Car feels like it hits a fuel dip.
I am running an EMU with a A/F target map
Old Dec 18, 2009 | 09:04 AM
jari8378's Avatar
Ill turn off the target map to see if the WB is the issue casuing the problem.
jari8378's Avatar
i hope it doesnt blow.
Old Dec 18, 2009 | 11:19 AM
TRBOKEV's Avatar
Something is going on... I would check your vacuume connection to your MAP sensor immediately and DONT boost the car until you get this figured out. Was my tune running a target map?
Do you have the wideband wired into the greddy now? A bad stand alone wideband will not effect how your car runs so that is definitely not the problemo..
Old Dec 18, 2009 | 01:08 PM
jari8378's Avatar
^^ fixed, i think. The connector was loose for option 1 on the EMU
and yes, you EMU map is also on a target map.
However I am using a new map.
Thanks, Kev
Old Dec 18, 2009 | 02:56 PM
dsddcd's Avatar
Thanks, Kev
So how is the beast running anyway. I never did hear did you get the boost controller working? How about any of the maps I sent did they help at all? Any Dyno numbers yet?
gacklez
Apr 15, 2016 03:46 AM
TerminatioN
Jan 25, 2012 03:56 PM
cpoz
May 21, 2009 02:46 PM
TRBOKEV
Sep 30, 2008 06:08 AM
derek14
Mar 2, 2007 06:24 AM
