Going For More WHP
Old Jul 19, 2006 | 04:35 PM
jdnissanz's Avatar
Thumbs up Going For More WHP
Ok guys my goal now is 400WHP-450WHP, without changing much of what I have. I know there are better turbos out there and better kits out there, but I have the Ultimate Racing Turbo Kit and that is what I have to play with. I have heard both good and bad thingws about adding 2mm to 3mm headgaskets, but to me it now seems like a "Band-Aid" fix. I was thinking about building my motor, but if I said that I wouldn't know the half to start such a process and I don't know where to begin and what to get. Also, someone tell me with the Ultimate Racing Turbo Kit and 550cc injectors how much power can I run without using all my injector? Then tell me if it is wiser to go the built route or the headgasket route? I really don't mind the headgasket, but scared I might mess up my motor and that is the last thing I want. I know I ask for more than I can chew, but I want a new challenge. As far as my ranting what do you guys think I should do? Also, if you pick one process over the other or if you can explain both clearly with prices and all then I would be very GREATFUL. Also, is the switch from Greddy Emanage to AEM EMS where all the power making begins or can similar SAFE power be made from the Greddy Emanage?
HELP!!! I seriously want to start this project soon so if anyone can chime in and lead me in the right direction. And I am not telling people to make me pick one over just tell me why you picked the one you did and pricing would help.
ME WANT POWER, AND I WANT A SAFE MOTOR...HAHAHAH can I ask for anything more?!?
PLEASE DON'T FLAME ME FOR THIS
3" downpipe Exahust (Single)
550cc Injectors
Greddy Emanage
Old Jul 19, 2006 | 08:11 PM
kane.s2k's Avatar
Timing control with the e-manage isn't all that great. You can make safer power with the AEM EMS. The headgasket is the way to go if you've got a good conditioned engine and low on $$$. If you have money, do it the right way. It never hurts to do it the right way except in the pockets.
Old Jul 20, 2006 | 05:13 AM
jdnissanz's Avatar
Can somone explain in a little more details what I have to do in addition to my current set-up to have a well running higher psi S2K?
Old Jul 20, 2006 | 06:22 AM
C45P312's Avatar
Build the motor and switch to AEM EMS
Old Jul 20, 2006 | 08:52 AM
jbotstein1's Avatar
You'll need EMS, built motor, boost controller, and a good tuner. I think with 550 injectors you won't be able to get much more than 400whp, but I also enjoy talking out of my ars
Old Jul 21, 2006 | 12:50 AM
s0rted's Avatar
Btw, how much boost are you running? I don't think you've mentioned that. Switching over to AEM ems and larger injectors, say 750cc, up the boost to 9-10psi, get a good tune and you'll get pretty close to the 400 whp mark. If you do a search there are a number of posts indicating that the stock engine can handle 10psi without a headgasket or built motor. that 550cc injectors are good for around 350whp and general consensus indicates they're the largest emanage can handle. Unless you up the fuel pressure greatly, (band-aid solution though) you'd be better off upsizing your injectors. Have a look at these posts for some ideas:
https://www.s2ki.com/forums/index.php?showt...0&#entry7100237
https://www.s2ki.com/forums/index.php?showt...0&#entry6520797
drhess06259
NES2KO Marketplace
Oct 29, 2010 04:46 PM
SliverS2k03
Jul 15, 2007 10:09 PM
Lil Asian808
May 22, 2007 10:52 AM
MorganHarding
Sep 6, 2005 02:13 PM
blackfx35
Jul 16, 2005 07:29 PM
