WHAT KIT
Old Aug 29, 2005 | 04:41 PM
MorganHarding's Avatar
Default WHAT KIT
i want to know what turbo is best to get. and how can i get 400whp safely what do you guys recommend that i do
Old Aug 29, 2005 | 05:03 PM
Scorpion's Avatar
For 400whp I recommend something like a GT30 turbo, running around 15-18psi. A commetic headgasket 2mm think will allow that much boost to run safely on the F20C. You'll need 750cc injectors at the minium, and atleast an Emange...better off with a full stand alone. Of course a good tune is needed, without it all the money in the world won't save your engine
Old Aug 29, 2005 | 11:24 PM
nsxinsac's Avatar
[QUOTE=Scorpion,Aug 29 2005, 05:03 PM] For 400whp I recommend something like a GT30 turbo, running around 15-18psi.
Old Aug 30, 2005 | 12:29 AM
jakub2000's Avatar
I would like to have that sort of power as well and thought 12-14psi should be fine on 98oct fuel...seems like I was daydremin'
nsxinsac why do you "might want to go with spring retainers, valve springs and head studs."? Not trying to start a flame war here, just wanna know whats the problem with the stock ones. Any knowledge on that?
Old Aug 30, 2005 | 06:15 AM
Birdie's Avatar
I always wonder how reliable are the thick headgasket like the 2mm and 3mm. If you think about it, putting a thick headgasket is a cheap way of building your block with low comp piston etc. so you can run more boost. But snice some of us dont have the cash flow for a built block and so forth. I would like more feed back about thick headgasket. I thought about running a thicker headgasket like 2mm so i can run 10-11psi, and just 8psi for daily. Anyone have good info on thick headgasket ?
Old Aug 30, 2005 | 08:27 AM
derek14's Avatar
Check out the topic for the new Full Race kit thats going to be released. The power is incredible on a stock block, and the craftsmanship is top notch too... just get your wallet ready
Old Aug 30, 2005 | 08:43 AM
Spoolin's Avatar
I don't believe you need that much boost to achieve 400 whp. Cody at LoveFab is now building me an equal length manifold and tested it yesterday. With my T3/T4 60-1 turbo, he said that on 8 psi it's going to be real close to 400 whp with the AEM.
Old Aug 30, 2005 | 10:01 AM
Birdie's Avatar
now that what im waiting for is the equal length one. SO anyone got any good info on headgasket ? I want to really do road racing with the lovefab kit. LOL
Old Aug 30, 2005 | 11:31 AM
double11's Avatar
best kit on the market for the s2k is the full-race. hands down.
Old Aug 30, 2005 | 12:03 PM
Birdie's Avatar
was the coolant problem from running the 2mm headgasket ?
