going in for a retune
Old Jul 2, 2007 | 06:24 PM
ChefJ's Avatar
Default going in for a retune
I am just curious as to if I should change the vtec crossover point from the factory setting to a higher or lower number?? I am running the inlinepro log manifold and sc61turbo .63ar. I am not looking for anything huge just a nice looking curve. Any experiences moving that cams set points??
Old Jul 2, 2007 | 06:38 PM
afwfjustin's Avatar
They'll be able to figure out where the car likes it on the dyno, but the log manifolds usually like it up higher near stock I believe. Where are you tuning at?
My new turbo should be here by Friday and I'll be retuning soon as well. Are you upping the boost? because I sure am
Old Jul 2, 2007 | 07:06 PM
5thelement's Avatar
yeah with the log manifold w had to leave my vtec crossover at about stock or a little higher with a better manifold i read on here people having them low at around 4800 i believe someone had theres at not sure but do a search migth come up
ChefJ's Avatar
I may go up to 14 psi but I am still on the stock clutch, which is holding up very well at 330whp and 220lb/ft. I have an appt at 10am with balanced performance.
Old Jul 2, 2007 | 07:07 PM
ChefJ's Avatar
I have seen vtec settings as high as 6500 for some log mani's. I just don't know if I should change it at all or just leave it alone.
Old Jul 2, 2007 | 07:15 PM
Spec_Ops2087's Avatar
The operator should be able to tell whether it needs to be changed or not, thats what your paying him for afterall
Old Jul 3, 2007 | 05:50 AM
Spoolin's Avatar
My VTEC crossover is set at 3500 rpm to achieve a smooth transition.
Old Jul 3, 2007 | 06:31 AM
gerdaland's Avatar
STOCK CLUTCH!!!???... idk how some of you guys do this, my stock clutch was gone after an intake and exhaust. good luck with ALL that.
Old Jul 3, 2007 | 08:00 AM
Spoolin's Avatar
Hmmmmm.........Someone doesn't know how to drive a clutch and is very hard on it maybe? My stock clutch made it up to about 335 whp before it started slipping.
Old Jul 3, 2007 | 09:30 AM
passmans2kny's Avatar
i have had intake and exhaust for over a year, my clutch is just fine
Chance S2K
Mar 22, 2016 05:58 PM
philistine
Jun 17, 2013 01:42 PM
Croc
Sep 12, 2012 04:43 AM
RedLineS2k10
Oct 9, 2010 01:19 PM
JRoche
Jan 30, 2008 08:14 PM
