going turbo!
Old Apr 28, 2008 | 03:29 PM
03silver2000's Avatar
would i be able to use this aem map sensor and boost control solenoid?
how does the boost control solenoid work?
http://cgi.ebay.com/ebaymotors/AEM-3-5-Bar...8QQcmdZViewItem
thanks jordan
Old Apr 28, 2008 | 03:44 PM
AusS2000's Avatar
Yeah you can use those.
You replace the stock MAP sensor with the AEM and calibrate the AEM EMS to accept it's signal. There is a wizard in the software and settings for the AEM 3.5 bar.
You can also use the boost control solenoid. You wire it to 12v and a pin on the AEM and configure it through the AEM software.
Old Apr 28, 2008 | 03:48 PM
AusS2000's Avatar
If you do get it get yourself one of these:
http://tunertoys.zoovy.com/product/MAPTER/...ivic_Turbo.html
Makes install a snap.
Old Apr 28, 2008 | 03:55 PM
is there anything else i cud use for a mpa sensor ithat is plug and play without having to also buy something like that
Old Apr 28, 2008 | 03:58 PM
also is there anything else i am going to need for my install any small things?
Old Apr 28, 2008 | 04:05 PM
AusS2000's Avatar
Sure, the Hondata 4 bar MAP sensor is the same shape as the OEM.
But there aren't any calibrations for it in the AEM software.
Old Apr 28, 2008 | 04:06 PM
how would i have the aem calibrated for it?
Old Apr 28, 2008 | 04:10 PM
AusS2000's Avatar
By going to a lot more trouble than installing the AEM MAP.
Old Apr 28, 2008 | 04:24 PM
so i wll need a aem 3.5 barmap sensor and a gm boost solenoid is thre anything else i will need for my turbo setup?
Old Apr 28, 2008 | 04:31 PM
AusS2000's Avatar
Your questions are a little vague.
I mean, do you think you need a clutch?
A boost gauge?
Heavy duty cup holder?
