Greddy E-Manage Ultimate
Old Aug 9, 2007 | 09:30 AM
  #21
jellyfish's Avatar
Originally Posted by MugenRioS2k,Aug 9 2007, 04:13 AM
Sound like our problem is pointing to improper jumper setting.
Specifically JP 13 and 14 need to be set to open
Out of the box only you should only moved JP 10 (2-3) and JP16 (1-2)
100% correct. All i had to do was adjust this, and then i used WLARUENTS settings for the "CH Settings" tab and problem solved. im going to give rewiring the harness a shot today, hopefully I will be able to montior my AIT once thats done with the same accuracy.
Old Sep 16, 2007 | 06:37 PM
  #22
jellyfish's Avatar
can anyone tell me what this message means?
ERROR DISPLAY:
[2007/09/16-19:22:38]------------------------
52:0443-0003[Incorrect 3CH ignition input signal]
[2007/09/16-19:28:55]------------------------
53:0442-0002[Incorrect 2CH ignition input signal]
when i went to connect my laptop to my emanage today, the "do you want to communicate in real-time" window came up, and at the same time so did a seperate widown with that inside of it. Whats the deal? Its been installed and running fine for over a month, and now there seems to be a bit of a misfire going on, and when i went to check my maps, this happened.
Maybe i kicked something and a wire is out? i've got no idea.
Old Sep 16, 2007 | 08:26 PM
  #23
WLAURENT's Avatar
I am guessing a wiring issue - even more so if you are getting a misfire and you are seeing the message off the eManage.
s2konroids
Sep 21, 2010 04:29 PM
Chris S2K
Forced Induction For Sale
May 19, 2010 11:45 AM
Chris S2K
May 19, 2010 09:20 AM
Partshelper
Jan 7, 2010 09:46 AM
jbotstein1
Nov 21, 2004 10:10 AM
