greddy kit numbers?
Old Jul 14, 2009 | 07:21 PM
macdaddies911's Avatar
Default greddy kit numbers?
I wanted to get an estimate of what kind of rwhp i should expect to see soooo..
1.) at what PSI are you running?
2.) what are you tuned on and where was it tuned?
3.) what supporting mods are you running (exhaust, TP/HFC)
4.) what year is your S, how many miles on the car, how many on the kit?
5.) Anything else of importance that may be important?
Old Jul 14, 2009 | 08:03 PM
*** also very interested if anyone is using stock exhaust and/or cat.
Old Jul 15, 2009 | 12:28 AM
boostftw's Avatar
so many greddy topics...
refer to:
https://www.s2ki.com/forums/index.php?showtopic=647911
https://www.s2ki.com/forums/index.php?showtopic=714553
Old Jul 15, 2009 | 10:23 AM
chad86's Avatar
With stock exhaust you will probably not break 300 hp
Test-pipe would help tho. the highest anyone has gone on a greddy is 12 psi with methanol injection...A member made 317 on a dyno dynamics which is very good because it is very low reading. A TP and exhaust will generally cause creep so you have to pick between them or port the WG. People have gone more than 20,000 miles on this kit so it is pretty good... but like Boostftw stated there is all the info you need in those topics... good luck
Old Jul 15, 2009 | 02:29 PM
lucky77's Avatar
Ive run 14psi with no meth for 15000 miles
Old Jul 15, 2009 | 03:48 PM
chad86's Avatar
WOW... hmmmm... WEll there you have it.... What octane fuel are you running and what HP did u get??? My tuner said the turbo was basically maxed out at 12psi and wouldn't make much/if any power any higher... Thats awesome tho!!!
Old Jul 15, 2009 | 05:32 PM
GPW03's Avatar
8psi
Hondata K-Pro - Tapp Auto (Canada)
Berk's HFC
2003 - 45,000km's - 600km's
I made 265whp and 189ft.lb.tq with a stock exhaust. I also have a Greddy BOV.
Old Jul 15, 2009 | 10:10 PM
lucky77's Avatar
Here in the UK i use 99RON fuel, i guess it would be the equivalent of your best super unleaded. The turbo will run 14psi for a while but unfortunately we cant get it to hold till redline, where its dropped back to 12psi. I made 336 @ wheels on Dyno Dynamics, Mase tuned.
whatthephucker
Jul 25, 2011 05:29 PM
macdaddies911
Apr 9, 2010 08:13 AM
Suzuka_Joe
Mar 1, 2010 07:29 PM
macdaddies911
Jun 24, 2009 12:00 PM
