Greddy Pressure sensor
Old Mar 24, 2009 | 09:55 AM
Revenge's Avatar
Thumbs up Greddy Pressure sensor
I am looking to obtain a greddy pressure sensor from another member, can this be easly removed and installed on another car or is somthing tapped in the motor and it can't be removed?
Thanks
Old Mar 24, 2009 | 09:56 AM
JoeyBalls's Avatar
I had P-tuning install mine, took them a few minutes I believe, sorry I dont have more details but seems like a simple install
Old Mar 24, 2009 | 10:03 AM
Revenge's Avatar
Do you know if they had to tap anything or is it just a plug and play? Also nice number when are you going up to 60psi?
Old Mar 24, 2009 | 10:05 AM
JoeyBalls's Avatar
haha 60PSI soon they didnt have to tap into the motor it looks like they used a t-fitting from my stock MAP sensor then to my emanage, I will go take some pics right now of what I think they did, or where I think they tapped , ill be back in 10 minutes
Old Mar 24, 2009 | 10:26 AM
JoeyBalls's Avatar
Ok, the RED DOT is where they tapped into for the pressure source
The YELLOW line is the vacuum line, and the yellow circle is the MAP sensor
The RED circle is the vacum like that is routed and plugged into somewhere, I believe the E-manage or the cars ECU
Old Mar 24, 2009 | 10:36 AM
Revenge's Avatar
thanks dude!!!
Old Mar 24, 2009 | 10:43 AM
JoeyBalls's Avatar
you got it brother
Old Mar 24, 2009 | 11:33 AM
RangOs2000's Avatar
Plugs into "option 1 or 2" on the emanage. Just tap into any vacuum line.
pussy
Apr 9, 2012 02:09 PM
s20004lifehomes
Apr 28, 2010 08:01 AM
jari8378
Nov 11, 2009 12:42 PM
NightStalker
Feb 7, 2006 02:42 AM
