greddy turbo kit installed, need some advise!
finally got my AP1 turboED. now running on base AP1 map. seems to drive fine. i like it over all, just need some time to get used to the fuel bump noise. will replace the spark plug to colder plugs see if i can solve the detonating sometimes.
my current setup is:
greddy turbo kit
stock cat
blitz dual realize TT cat back
my concern:
1. the car is boosting fine, however, i m feeling the torque drops obviously when reaching 6k rpm in all gears. engine also sounds differently after 6k rpm, vtec engage?! rpm raises kinda slow after 6k. is that how people call the vtec dips? is that normal? how can i fix that?
2. is my blitz exhaust restrictive? i check the diameter is a 60.5mm. thinking of getting the greddy TI-C dual, dont really know the diameter however. will the greddy dual improve the power? i like the dual exhaust.
i'll tune the car in the future, but i will stay with the base map and stock cat for a while.
i'll try to put on a boost gauge and read the current boost.
thanks.
KELvin
greddy turbo kit
stock cat
my concern:
thanks.
KELvin
so the torque drop in 6k rpm seems to be normal?!
i've also done some research the single exit exhaust is always perform better than dual. is that ture? i was searching the diameter for the greddy TIC dual but most of them say 50-80mm. and the single greddy TIC is 70mm in pipping. should i just go for 70mm+ single exit for performance and lighter in weight?
seems like most people recommand me a tune. if i m getting it to tune, i'll get the test pipe for sure.
what are some good place to get my 2k tuned in the bay area?!?
thanks.
KELvin
thanks.
KELvin
Yeah, get tuned, a HFC and a better exhaust around the 70mm range, also a good boost controller really helps . Then check back. You probably feeling the vtec dip accosiated with the kit as well.
