greddy turbo problem
Hello all,
for a base info, Im running the HKS exhaust and Greddy turbo. no BOV.
we finished the install today, and she started up fine. BUT, i put her in first gear and slowly gave power and she boged bad!.. i gave her more gas and she still the same, almost like she wants to stall. but once you get the rpms up she's fine. From a full stop, then easy throttle, she'll buck hard.
with in a few drive around the block, the check engine light came on. We checked the Emanage, but its all green. We unpluged the battery to reset the ECU and it cleared.. but after a 30min drive, the light came back on..
We looked for a vac leak but nothing.. do you guys have any ideas???
Originally Posted by Envied,Feb 17 2008, 06:37 PM
Maybe you should have the code checked to see what the problem is that ecu is seeing.
