Greddy turbo shaft play normal?
There should no play in the shaft of a turbo/supercharger. Minimal play might not be a problem for a short while but turbos spin at such high rev's that the shaft play will get worse over time.
Originally Posted by S2KSandy,Feb 28 2008, 01:01 PM
i wiggle mine all the time........back and forth....side to side........works perfect! HAHAHAHA
YES side to side shaft play is NORMAL (to a certain extent) in greddy turbos since they use sleeve type bearings. There are small clearances between the bearings and the internals of the turbo that oil needs to pass through. Once oil pressure is in there, there won't be any side to side shaft play, thus you will be ok.
In and out shaft play is BAD, that means you have worn parts and need a rebuild.
