Greddy Type-RS BOV Question
Ok When I switch gears I get the "whhooooooooopish" followed by the "rattlesnake" noise, I guess I have to turn the screw towards the "Softer" side, however when I turn that nut, it just loosens itself, or gets to a point until it is too tight to move, and nothing else moves. The BOV sounds the same, what the hell am I doing wrong? Do I have to take the BOV off and do it?
Are you adjusting the screw with an allen wrench one the lock nut is loose?
If so, then try checking the nipple on the BOV itself. Mine was somewhat loose so I removed it and placed teflon tape on the threads to get a better seal.
You should not hear any surge noise once you have it calibrated right. Mine still surges when the engine is COLD but once it warms up, I get a nice clean BOV sound.
Originally Posted by nightcrawler7188,Mar 17 2008, 12:38 PM
loosen the nut and adjust the allen bolt
i was a dumbass for like an hour and made the same mistake
. Basically it is as "Soft" as it will, go any softer and the bolt will fall out, hope that setting is fine, sounds great, nice and smooth.I don't really race on the street but as I was "testing" my new BOV setting one of the new Infiniti G37 type S pulls up next to me then hits I hit it and to my sad surprise I really didn't make much ground, didnt lose any either. Light ahead turns Red, he more then willingly pulls to the right so he can have the right lane, I will take the left. ----a few weeks ago before I was Turbo, I lost to one of these things, raced the guy twice and both times into 3rd gear the G37 walked away------So now heart is starting to pound slightly, after all this is my first "race" after the Turbo, so light turns green, he jumps off the line, myself being ridiculously scared to break anything, start off very normal off the line, as if I was not going to race, when I get in 1st gear, I hit it, Tires spin, I finally get grip as I switch into 2nd, by this time he is half a car ahead of me, we are pretty even due to my poor driving skills until around 60mph, or early 3rd and I take off, and I mean I pull away very easy (my car was backfiring & bogging slightly as I switched gears), so I decided enough is enough around 111mph, I slow, he flies by, but gives me the two honks
Can't wait to get rid of my cat and get a tune, hopefully I won't need 3 gears to beat a high 13 second car
Originally Posted by devs2k,Mar 17 2008, 01:23 PM
^i think you should take it easy until you get a tune
Originally Posted by JoeyBalls,Mar 17 2008, 05:47 PM
Yeah, I know................Car has been driving fairly well as of late ( I think its the warmer weather?) I am not going to press my luck anymore
mine will be done soon hopefully
Sounds like your having fun with the car. The other day a heavily modded WRX was next to me on the freeway and took off. I left it in 6th while he downshifted. We were even up to 120 when I decided to let off since I'm not tuned. He gave me the thumbs up as did I.
. I just ordered the CR Side markers, and some Silver "S2000" Caliper stickers as I will paint the calipers black, then clear coat them, the OEM Front lip is also on its way
I am very happy with how the car is coming along. Can't wait for the summer
Start going to some car showsOf course when I am all done, & Tuned I will probably wish I went the InlinePro Way
. Next up mod wise will be clutch and Flywheel, then hardtop for the Fall. Saw a Red S2000 with Dealer plates on a flatbed this afternoon, somebody went out for a Test Drive and lost control of the poor thing..........ahhhhhhh Spring is almost here
